Re:¿cómo empiezo para instalar la última versión de Hackintos?
iATKOS S3 V2 - Hackintosh Mac OS X 10.6.3 (Snow Leopard)
Con Sonido, Red, y Grafica (para una p35) aunque se supone que es compatible con casi todas las placas.
Con posibilidad de actulizar el operativo hasta el 10.6.4
Con soporte para procesadores Intel y AMD.Athlon 64 (“Orleans”
Athlon 64 X2 (“Windsor”)
Athlon 64 FX (“Windsor”)
Athlon 64 and Athlon 64 X2 family of processors with “F” or “G” stepping on socket AM2,
Turion 64 X2, and Opteron 2nd generation and 3rd-generation,
Phenom and Phenom II processors.
AMD-V is not supported by any Socket 939 processors. The only Sempron processors which support it are Sable, Huron and Sargas.
Sistema Operativo: MAC OS X Snow Leopard 10.6.3. Con soporte para procesadores Intel y AMD.
CPUs
Athlon 64 (“Orleans”)
Pentium 4 662 and 672
Pentium Extreme Edition 955 and 965 (not Pentium 4 Extreme Edition with HT)
Pentium D 9x0
Core 2 Duo E6300, E6400, E6320, E6420, E6540, E6550, E6600, E6700, E6750, E6850 (Conroe)
Core 2 Duo E5400, E7600, E8200, E8300, E8400, E8500, E8600 and some versions of the E7400 and E7500 (Wolfdale)
Mobile Core 2 Duo T5600, T6670, T7100, T7200, T7250, T7300, T7400, T7500, T7600G, T7700, T7800, U7500, L7200, L7300, L7400, L7500, L7700, U7500, U7600, U7700 (Merom)
Mobile Core 2 Duo SU7300, SU9300, SU9400, SU9600, SL9300, SL9380, SL9400, SL9600, SP9300, SP9400, SP9600, P7350 (mac), P7370, P7550 (confirmed), P7570, P8400, P8600, P8700, P8800, P9500, P9600, P9700, T8100, T8300, T9300, T9400, T9500, T9550, T9600, T9800, T9900 (Penryn)
Core 2 Quad Q6600, Q6700 (Kentsfield)
Core 2 Quad Q8400, Q8400S, Q9300, Q9400, Q9400S, Q9450, Q9550, Q9550S, Q9650 and some versions of the Q8300 (Yorkfield)
Core 2 Extreme X6800 (Conroe XE)
Core 2 Extreme QX6700, QX6800, QX6850 (Kentsfield XE)
Core 2 Extreme QX9650, QX9770, QX9775 (Yorkfield XE)
Xeon 3300 and +, 5000, 7000 series
Atom Z520, Z530, Z540, Z550 (Silverthorne)
all Intel Core i3 processors
all Intel Core i5 processors
all Intel Core i7 processors
Pentium Dual-Core E6300, E6500, E6600 and some versions of the E5300 and E5400 * [1]
Celeron SU2300, E3200, E3300, E3400
INSTALACIÓN
Para instalar solo hace falta arrancar desde el dvd, presionar intro o f8 para arrancar con opciones, entrar en utilidad de discos para borrar la particion donde la vamos a instalar y que se quede en formato MacOsX con registro, salir de utilidad de discos e instalar.
Antes de comenzar la instalación, hay un boton abajo a la izda que pone “personalizar” ahi puedes seleccionar lo que quieras que se instale.
Es recomendable no seleccionar cosas que no sepaslo que son, y fijarte en la descripcion (cuando seleccionas algo como un driver fijarte en la descripción que aparece abajo en la cual te puede indicar que solo debes instalar uno de los 2 drivers de ati por ejemplo.)
Configuración con la que me funcionó: (antes de instalar pulsas “personalizar” instalacion)
Seleccionamos
en USB->USBBusFix, EHClacquire y UHCIreset
USB-> USB( modified IOUSBFamily.kext for usb problems)
Sata->AHCI
Nvidia->
EFI String-> (dvi/dvi) pq mi grafica tiene dos salidas dvi
Enablers-> NVEnabler
Ntfs-3G
y dejamos lo que viene por defecto ya marcado.
Con esto me funciona la gráfica 9600gt con QE/Ci sin instalar nada, red, sonido, todo menos que no me monta los pendrives usb (a menos que en el arranque especifique USBBusFix=Yes)
(espero que os sirva de ayuda)
Posibles problemas:
La máquina se reinicia y no llegamos a empezar la instalación: intenta pulsar f8 cuando sale el camaleon y teclear “-x -v” (si aun asi no puedes arrancar prueba con "-x -v busratio=20) el número busratio es algo asi como cuanto mas potente sea el micro más número hay que poner. El 21 es para un i5, el 20 es para un 775.
Esto creo que no es del todo correcto pq haciendo otras instalaciones me di cuenta que parece ser que el busratio equivale al multiplicador del procesador (lo podeis mirar en la Bios) y aparecerá como x21 o x20…
Si una vez instalado todo reiniciamos por primera vez y sale una pantalla gris claro y unas letras que dices que presiones el boton de apagar (esto significa que tu gráfica no es compatible, tienes que seguir arrancando con f8 y con -x)
Si despues de instalar no te detecta el teclado o el ratón ( deberias haver instalado al principio de la instalación los drivers, esto se hace asi, cuando vas a empezar la instalación aparece a la izda un boton “personalizar” selecciones drivers y/o patches y marcas algo que pone ps/2 y usb fix, si no tienes ps/2 no hace falta que lo marques. Es recomendable seleccionar el usbfix y otro que se llama “usb” uno esta en drivers y otro en patches.)
https://www.megaupload.com/?d=54PSL8XQ
https://www.megaupload.com/?d=4BROMFH0
https://www.megaupload.com/?d=N93VNEDP
https://www.megaupload.com/?d=X3FWH85D
En 4 links sin password aver si os vale…
